It is currently Thu Aug 14, 2025 1:33 am
PostPosted: Fri Oct 30, 2015 9:39 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I can't remember the solution for this. Is it drill an angled hole in end of slot? You can't clip the active part, right?
PostPosted: Fri Oct 30, 2015 9:49 am
City: Lawrence
Zip/Postal Code: 66047
I think your right, if you clip the active part you kill the pickup.
PostPosted: Fri Oct 30, 2015 9:51 am
viewtopic.php?f=10101&t=46554
PostPosted: Fri Oct 30, 2015 10:04 am
Two solutions:
One buy the Collins Saddle Mill....:) for $2700 and elongate the saddle slot..... (KIDDING OF COURSE....)
Two: drill a hole at a sideways angle into the slot end and below the visible surface that will be suitable to tuck the transducer tip into. This is a practice that we've detailed before on the OLF and we do it all of the time. The transducers usually are pretty dead near the tip anyway so this takes the dead spot out of play and neatly tucks it under the end of the saddle slot. Mind you you don't want the hole to come through the bridge and you also don't want the tool marks to show outside the saddle slot so the drill bit should be no bigger than required for the transducer element tip but smaller than the slot width.
I'll add that if the transducer is braided it's helpful then place the saddle on top of it and tap it with a small hammer with the saddle crown protected in leather. The point of all of this is to gently mash the braided element into a more uniform and complete contact with the saddle bottom.
It's also helpful to have the saddle loose enough that it pulls out with finger tip pressure but never so loose so that it has any wiggle room to tip one way or the other. The point of this is to be sure that the saddle can travel on top of the transducer freely.
As for the other end of the transducer where either the braided element continues or there is a wire an angled hole taking care to never, never, never drill though the X brace or any other brace and Bob's your uncle.
PostPosted: Fri Oct 30, 2015 10:32 am
I'm with Hesh on the saddle. I fit them so it slips in easily (I actually like it to be able to slip out if I tip the guitar over), but with no tipping. If its an air fit, when the guitar takes on humidity you may find the saddle doesn't fit the transducer correctly, and the added fun of a saddle that doesn't want to come out of the slot.
PostPosted: Fri Oct 30, 2015 11:47 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Ok, tuck it. That's what I was thinking
PostPosted: Fri Oct 30, 2015 9:49 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
It worked. Thank you
